96 Tahoe speedo trouble
Old Nov 2, 2014 | 10:17 PM
jason71's Avatar
Default 96 Tahoe speedo trouble
Ok, I will eliminate a lot of early trouble shooting, I have tested the VSS, (all 3 of them that came with the vehicle test good) so for 25 bucks I bought a new one. I have ohmed the wires from the VSS to the ECM under the hood, I have also checked the fuses in the speedo and cruise circuit, My next test is the reluctor wheel in the tranny, I will jack up the rear end and test for signal voltage from the sensor....... IF THIS IS NOT THE PROBLEM.... is there any advice on where to go next?? I also replaced the speedo cluster with a good one. Any advice is greatly appreciated.
Thank you
kystang90
Nov 30, 2010 9:15 PM
dozer157
Sep 8, 2009 7:32 PM
bostonkillers
Feb 12, 2007 12:41 AM
b1pig
Nov 21, 2006 2:35 AM
