97 Tahoe Fuel issue?????......
Old Nov 6, 2009 | 7:41 PM
rudy123's Avatar
Default 97 Tahoe Fuel issue?????......
So im new to here but it seems like a good place to start..I have a 97 tahoe and out of no where it stopped running.Me and my friend troubleshooted a lil bit and found out that theres a problem with the fuel.we cant hear the fuel pump kick on but someone was telling me to find the fuel pressure valve and see if theres any pressure before i start tearing apart things.Has anyone ever had this problem before and can anyone tell me where the fuel pressure valve is?i would appreciate!!!!
Old Nov 7, 2009 | 1:45 PM
rudy123's Avatar
this is my first chevy..is it hard to change out the fuel pump?has anyone changed one out before and is there a link or DIY page that someone can help me out?
Old Nov 9, 2009 | 6:01 PM
timdogg1313's Avatar
Welcome! Can't help you on the fuel pressure valve, but the fuel pump is located in the gas tank, so yes it is a chore to replace. Hope this helps some and good luck. Please post what you find.
Old Nov 9, 2009 | 6:31 PM
rudy123's Avatar
well thanks alot.atleast someone wrote back and said something.lol..thanks and i will post up the results when i get to work on my truck.it will probably be this weekend.
Old Nov 10, 2009 | 10:09 PM
95BurbanAZ's Avatar
im not sure where u would be able to find a valve to check fuel pressure, but i do know that the fuel pressure regulator if u have TBI is on the fuel injector pod on the back kind of between the 2 injectors, so u could try changing that out because its a pretty cheap part, also if its TBI u might want to try taking off the air filter and having someone start it and make sure that u have a good spray pattern and that the injectors arent clogged or something. Also if u think they are clogged u can buy some sea foam from checker or autozone or something and run that through the system that usually works pretty good
Old Nov 16, 2009 | 1:17 PM
tahoe1999's Avatar
Default fuel pressure
if you take the plastic intake off of the throttle body there is a little vavle for you to hook up a fuel pressure tester its right behind the throttle body
Old Nov 19, 2009 | 10:29 AM
east302's Avatar
The pump is on top of the tank so, yes, you'll have to drop the tank to replace it. Or, I saw where someone cut an access hole in the cargo floor instead.
Old Nov 19, 2009 | 3:40 PM
rudy123's Avatar
so everyone...i think i might of fixed the problem but you guys decide...i went to go get my truck towed so i can work on it today..but instead..i got a rubber mallet and tapped on the outside of the gas tank...she started right up!!! i put some sea foam in the tank and put some more gas in it cus there was like only 1/4 tank in there..but now shes running perfect and starting everytime!!! does anyone know if im in the clear or should i still repplace the fuel pump?any suggestions would be nice..thanks alot again for everones advise before
Old Nov 19, 2009 | 4:55 PM
east302's Avatar
Someone else will probably chime in, but I've always heard that hitting the tank will sometimes jolt the pump back into action as a temporary fix. I even tried it last weekend when my truck (98 Z71) wouldn't start...no dice. I got hit for an $800 repair bill for that fuel pump. Not fun.
To be sure, you could get a shop to test the fuel pressure and then you'll know for sure.
Old Nov 19, 2009 | 5:02 PM
rudy123's Avatar
well thanks alot man.im gonna get that done today because im supposed to be taking it on a trip tomorrow.do you by chance know what the psi rating is suppose to be?
