98 suburban recalls?
Old Apr 21, 2008 | 10:28 PM
mackiecfx16's Avatar
Default 98 suburban recalls?
could someone tell me if and what the recalls on that 98' suburban 1500's are
i have one and im jsut curious if it could be the reason to some of my problems
thanks alot
Old Apr 22, 2008 | 10:48 AM
ZX1100F1's Avatar
Default RE: 98 suburban recalls?
If you will provide your VIN I would be happy to see if your Suburban has any outstanding campaigns (recalls).
There were very few recalls on the 98 Suburban, only one safety related which had to do with adding a fused jumper harness to the power outside rearview mirror switch and this campaign only applied to a handfull of Suburban's.
Old Apr 24, 2008 | 8:27 AM
hquick's Avatar
There's a good chance the windscreen wiper cct board is covered.
Old Jun 22, 2008 | 12:30 PM
n4tit's Avatar
1. VISIBILITY:REARVIEW MIRRORS/DEVICES:EXTERIOR
Vehicle: 1998 GMC Suburban Defect Description:
CERTAIN SPORT UTILITY VEHICLES, MINI VANS, AND PICKUP TRUCKS MAY DEVELOP A SHORT CIRCUIT IN THE ELECTRIC OUTSIDE REARVIEW MIRROR SWITCH. Consequence of Defect:
IF THIS WERE TO HAPPEN, IT COULD RESULT IN AN INOPERATIVE SWITCH, HEAT DAMAGE TO THE DRIVER-ĘS DOOR, AND/OR IGNITION OF COMPONENTS IN THE DRIVER-ĘS DOOR AND A SUBSEQUENT VEHICLE FIRE WITHOUT PRIOR WARNING. Corrective Action:
DEALERS WILL INSTALL A FUSED JUMPER HARNESS TO THE ELECTRIC OUTSIDE REARVIEW MIRROR SWITCH. OWNER NOTIFICATION BEGAN ON APRIL 24, 2003. OWNERS WHO TAKE THEIR VEHICLES TO AN AUTHORIZED DEALER ON AN AGREED UPON SERVICE DATE AND DO NOT RECEIVE THE FREE REMEDY WITHIN A REASONABLE TIME SHOULD CONTACT CHEVROLET AT 1-800-222-1020 OR GMC AT 1-800-462-8782.
2. FUEL SYSTEM, GASOLINEVehicle: 1998 GMC Suburban Defect Description:
CERTAIN REPLACEMENT FUEL FILTERS, FRAM BRAND NAME P/N G3727, WITH DATE CODES X52911 THROUGH X60801 SEQUENTIALLY OR X600141 AND A MEXICO COUNTRY OR ORIGIN MARKING ON THE FUEL FILTER HOUSING MANUFACTURED FROM OCTOBER 18, 2005, THROUGH MARCH 21, 2006, SOLD FOR USE ON THE VEHICLES LISTED ABOVE AND ON CERTAIN SCHOOL BUSES. (TO SEE THE SCHOOL BUS ENGINE SIZES, CLICK ON "DOCUMENT SEARCH" AND THEN "BUS APPLICATIONS"). THE CONNECTOR ON THE FUEL FILTER WAS NOT MANUFACTURED TO HONEYWELL'S SPECIFICATION. AS A RESULT, THE O-RING MAY SEAT CORRECTLY ON THE FUEL LINE. Consequence of Defect:
THIS CONDITION MAY CAUSE AN INADEQUATE SEAL AT THE CONNECTION, POTENTIALLY LEADING TO A FUEL LEAK. IN THE PRESENCE OF AN IGNITION SOURCE, A FIRE COULD OCCUR. Corrective Action:
HONEYWELL WILL NOTIFY OWNERS AND REPLACE THE FUEL FILTERS FREE OF CHARGE. THE RECALL IS EXPECTED TO BEGIN DURING MAY 2006. OWNERS MAY CONTACT FRAM CUSTOMER SERVICE AT 1-800-890-2075 (OPTION 1).
3. BRAKES:HYDRAULICISC:ROTORISC HUBVehicle: 1998 GMC Suburban Defect Description:
VEHICLE DESCRIPTION: LIGHT DUTY PICKUP TRUCKS AND MULTI-PURPOSE PASSENGER VEHICLES. ONE OR BOTH FRONT BRAKE ROTOR/HUBS WERE BUILT WITH AN OUT-OF-SPECIFICATION GRAY IRON THAT CAN FAIL DURING THE LIFE OF THE VEHICLE. Consequence of Defect:
IF A DRIVER CONTINUES TO DRIVE WITH A CRACKED ROTOR, THE CRACKS COULD CONTINUE AROUND THE WHEEL MOUNTING BOLT CIRCLE AND ULTIMATELY RESULT IN A WHEEL SEPARATION. Corrective Action:
DEALERS WILL INSPECT THE ROTORS FOR A CORE DATE OF "287" AND, IF FOUND, REPLACE THE ROTOR.
There are also 93 Technical Service Bulletins
You can find more info at http://www.edmunds.com/maintenance/MaintenanceServlet
blueinterceptor
Nov 29, 2012 8:47 PM
tm4hammer
Sep 30, 2009 8:25 PM
!aaaventure3
Apr 25, 2009 10:51 AM
domnicmacado
Jul 24, 2008 7:17 AM
houszton
Jul 24, 2006 8:52 PM
