98 suburban tires 4x4
Old Oct 27, 2015 | 1:42 PM
Michael0641's Avatar
Default 98 suburban tires 4x4
I have a new set of 265/75/16 tires on the front of my suburban and was looking to get 285/75/16 for the rear. i will be replacing them all when they wear down with the same size all around. But i was wondering if this will cause problems with 4wd. All tires are brand new and same amount of tread. even the same brand tire. thanks
Old Oct 27, 2015 | 3:32 PM
Scotiapilot's Avatar
Yes, it will likely cause the transfer case issues Don't do it.
Old Oct 28, 2015 | 10:52 AM
SWHouston's Avatar
Scotiapilot is quite right, but it will cause a lot more than just with the XCase. Your ABS, a probable attempt to lockup when in either 4WD, or serous chirping (speed differential) issues as well.
ALWAYS, same size on all four !
