98 Tahoe
Old Feb 23, 2012 | 5:06 AM
Tahoe89's Avatar
New User
Awaiting E-mail Confirmation
Default 98 Tahoe
I have a 98 tahoe 4x4. I have recently had problems starting my tahoe (only every few days). When it would act up it would crank but not turn over on the first try (like usual). I let it sit for alomost a week and it would just keep cranking but wouldn't start. I replaced the Battery (it was bad). Still the same problem. I hear the fuel pump. Spark plugs and wires about a year old. And I also smell fuel after trying to start. Im thinking the spark is the problem but I dont know all I should check. Any suggestions?
Old Dec 26, 2013 | 8:30 PM
chevyfix's Avatar
did you check the coil for spark
Old Dec 27, 2013 | 2:01 PM
trainwreck91's Avatar
sounds like you're not getting fuel to the motor. those were my first thoughts before you even mentioned that you smell fuel...so my next guess is theres a fuel leak somewhere. also check your fuel filter. it should be along the inside of the frame. be careful if your going to check the spark if there is a fuel leak because you might start a fire
might sound stupid but are you almost on E and are you parked on a hill?
