98 Tahoe die's @ low speeds
Tahoe 4x4 125k mi., intermittently die's at low speed cornering or acc from a stop.
Starts right back up. Replaced plugs and wires @100k, fuel filter also. Luckily
ran fine during last weeks sleet and ice. Now back to acting up. I'm thinking fuel pressure, but like I said it's intermittent. Any idea's? Thanks
First new vehicle we ever ordered, and intend to keep another 125k mi.
98 5.7 350 vortec 4x4
I'd consider having the fuel system serviced if you have not had that done, an easy way to find out if that is the issue is run a couple or three bottles of injector cleaner thru a full tank and see if it improves..
We can't assume the obvious in the forum...well because its not always obvious...
I'd try checking the EGR valve it could be sticking,
check electrical connections to and from battery especially grounds
