99 with 5.7 bogs down after warm starts occasionally
Old Jul 3, 2022 | 1:37 PM
SAR's Avatar
SAR
Default 99 with 5.7 bogs down after warm starts occasionally
99 C1500 Suburban with 5.7.
Over the past few months it has been bogging down occasionally when accelerating immediately after a warm re-start (perhaps 5-10 times over 4 months). Our ambient temps here are rarely above the mid 20's C (~75F), so the issue seems only to be engine temp related. Only notice the bogging when accelerating on entry to a road where throttle is called for. The bogging only lasts for 5-10 seconds or so then power comes on - it is not accompanied by stumbling, missing or other symptoms - just no power. Once it clears, the engine runs fine and if I shut down and restart immediately to try to recreate the issue, I've not had it repeat - so it seems to be related to a period where the engine can heat soak for a few minutes but not cool down (like stopping for fuel or a short stop at a store).
The truck always starts immediately on cranking. There are no codes, no misfires and fuel trims, O2 sensors, MAF etc look good on the scanner (I use a Foxwell). I've hooked up a fuel pressure gauge and taken it for a drive and all seems to be OK. I read 52-53 psi at idle & 58-60 when revs are >1000 with no fluctuations. Pressure holds w/in 10 psi for over an hour on shutdown. NB that the engine was converted to MPFI several years ago and these readings match tests done then & as I understand are in spec for the MPFI system.
I've replaced the fuel filter, rotor/cap and plugs - no change. Plugs and wires are fairly recent and look OK.
Suggestions on where to look next are welcome - could it be running too rich on restart, be a fuel volume issue or ??
BW5.7
Dec 29, 2022 7:47 PM
oldandintheway
Jul 1, 2020 9:12 PM
99SuburbanTX
Sep 30, 2013 7:53 AM
ed1le
Apr 17, 2010 7:41 AM
gjd99tahoe
Mar 9, 2009 7:43 PM
