99 burb stuck in 4x4
Old Sep 10, 2017 | 10:08 PM
Silentcrow2003's Avatar
Default 99 burb stuck in 4x4
I tried searching on here but couldn't really find much. I have a 99 Suburban I just picked up. shifted it in four-wheel-drive now it won't come out. The lights on the indicator don't really light up and it's only four wheel drive doesn't go into 4 Low. I've messed around with it a little bit and the only thing that I can find to make it go into 2 wheel drive is to pull the transfer case fuse and it shifts into 2, put it back in and it goes back into 4.does anybody possibly know what's causing this?
Old Sep 17, 2017 | 6:52 PM
Randall Oliver's Avatar
Man I thought I was the only one going through this. Do you have the slt?
Old Sep 17, 2017 | 7:09 PM
Slt? The trim package? I think it's just LT I'd have to look. Got it to go back into 2wd think my problem lies in the push buttons. After startup and driving for a few miles the service 4wd light comes on. I'm going to change the tc fluid and try and find new switch at a wrecking yard. To get it to shift you gotta push and wiggle the button and hold it for it to finally shift.
Old Sep 17, 2017 | 9:39 PM
kevinkpk's Avatar
Pull the transfer case shift motor, go from there
Old Sep 22, 2017 | 12:46 AM
I found a different selector switch at a wrecking yard swapped it out and it seems to shift just fine the problem I'm seeing is that there is some solder on the circuit board that's broke that needs to be fixed
