99 k15 suburban deceleration grind?
Old Aug 22, 2016 | 10:19 PM
Xjorburban?'s Avatar
Default 99 k15 suburban deceleration grind?
99 k15 sounds like front brakes grinding on deceleration. Completely replaced brakes, hubs, halfshafts,shocks. Checked front diff,tcase,trans fluids. Took front drive shaft out this evening, still grinding. Only happens after I get the drive train hot. Only over 35 , and only on deceleration. I'll throttle it hard enough for it to shift,then when I release the pedal, the mystery grind for a couple seconds. Truck has same torque and power it's had since I bought it,shifts flawlessly and the engine couldn't be much smoother with190,000 and no maintenance records. I am no Mechanic and am getting out of my comfort zone with this truck on my mechanical abilities. Had anyone had a similar issue, or could maybe tell me if I should take this to a transmission shop, or what? I'm pretty well stumped don't know if I should stop driving it.
