'99 Sub brake switch prob.
Old Nov 15, 2013 | 10:10 PM
bilzhorse's Avatar
Default '99 Sub brake switch prob.
My '99 Suburban has a problem with the brake light switch. It will make a clicking sound continuously and it eventually runs down the battery. I replaced it with a new one and the problem is still there. What could cause this and how do I fix it? Thanks.
Old Nov 17, 2013 | 4:23 PM
Is it the switch itself or something nearby?
Old Nov 17, 2013 | 6:29 PM
bilzhorse's Avatar
Its the switch. When its making the noise I can depress the brake pedal slightly and it will stop.
Old Nov 17, 2013 | 7:29 PM
That makes it sound like it's more in the brake lite circuitry that's being activated by closing the brake light switch.
Old Nov 18, 2013 | 7:39 AM
bilzhorse's Avatar
Any suggestions? I've already replaced the switch. What else is there? I really can't see anything because of where it is. The steering column is in the way.
Old Nov 18, 2013 | 6:29 PM
Dave01's Avatar
Those switches are a common problem, and the wiring to them as well. I had one on a '97 that would stop operating, and I could reach under, wiggle the wires until it worked, and it would stay working for a day or a week. Finally I replaced the switch but I really think the problem was the wiring that went to it. I'd suggest that when it's clicking you get under there, and without depressing the brake try to find a wire that's frayed or badly connected, move things around until it hopefully it stops. Also, is your cruise control working ok?
mware88
Nov 15, 2013 6:59 PM
taw2db
Nov 6, 2009 5:25 PM
mace
Mar 12, 2008 6:40 PM
Smithergy
Aug 15, 2007 2:19 PM
