99 Sub, no brake lights and no blinkers??
my 99 Suburban lost it's brake lights and turn signals
I have checked both fuses and they are not blown as well as checked the fuses under the hood and all are ok there as well??? what has happened? is there a fuseable link somewhere that I am missing?
please help
thanks
please help
thanks
My turn signals work but not the brake and hazard flashers but the brake light works on the top of Sub. Is there a way to by pass the multifunction switch? Tap into the wire that goes to the upper brake light? Any ideas.
Thanks
Thanks
I don't think you can bypass the multi switch. Go to the salvage yard and get another one. May want to check your tailight recepticled for the bulbs. Mine lost the left brake and turn, pulled it apart to find this white "goo" in there, cleaned it with terminal cleaner and now is good to go.
stank911
Apr 30, 2014 7:14 AM
Samanthastevens
Oct 17, 2010 8:08 PM
captains
Nov 20, 2007 9:12 PM
