99 Suburban 5.7L: misfire and wet plugs
Old Mar 10, 2013 | 8:20 PM
Alwaysdutch's Avatar
Default 99 Suburban 5.7L: misfire and wet plugs
Hi there,
I am new to the Chevy forum as my stepdaughter bought a 99' Suburban. It runs pretty good but has the following issues:
- A P1351 and P0308 code.
- A smell that the engine runs rich
- A slight misfire.
- Wet spark plugs #6 and 8, most likely gasonline
The truck needed a tune-up so I replaced the following:
- Spark plugs type AC Delco Rapidfire ones (gap 0.060)
- Replaced the plug wires with the Autozone ones
- Did a traditional oil change
- Replaced the ICM as it was the most common item on the P1351 list
I reset the CEL but I still feel a slight idle issue as a misfire. I need to get this truck through emissions ASAP so I was hoping I could get some ideas from anyone in regards to the misfire and the wet plugs.
Thanks!!
Old Mar 10, 2013 | 9:56 PM
MDTAHOE's Avatar
Professional Mechanic
Most likely need the fuel injection unit. It has been updated to a better design.
Old Mar 12, 2013 | 11:53 PM
I assume you are talking about the spider injector unit?
Also, I noticed that Autoaone gave me the wrong spark plugs, so they go back and replaced with the AC Delco double platinum. Should I go iridium instead??
One thing I noticed is that the plugs are wet and that there is gasoline coming out of the exhaust when cold. Why is that happening??
Alwaysdutch
Oct 16, 2015 8:04 AM
benwinch
Aug 16, 2014 9:41 PM
kschatta
Mar 30, 2008 10:37 PM
dbrog28301
Colorado
May 21, 2007 9:48 PM
