99 suburban backfiring
Old Sep 19, 2018 | 10:45 PM
99burban5.7's Avatar
Default 99 suburban backfiring
Okay so im hoping you guys can help me out or at least point me in a good direction. Heres the issue my suburban was running fine till i was driving about 35mph and it backfired twice and died out. Ive replaced the timing chain, distributor, camshaft sensor and, checked my firing order. It turns over but hesitates and backfires. Any input on what it could be?
Old Sep 21, 2018 | 3:29 AM
oilcanhenry's Avatar
You have any OBD II codes for us?
Old Sep 21, 2018 | 8:30 AM
geo1's Avatar
That truck has coil and module?only items left for ignition
Old Sep 21, 2018 | 1:37 PM
falconbrother's Avatar
You're 100% sure the cam timing is correct? And, that it's synched with the ignition? Make sure.. Considering the timing chain was replaced this could have changed and that would do it.
Old Sep 21, 2018 | 7:47 PM
how do i check of the cam timing is synced? I lined up the two dots at the 12 o’clock position like it was supposed to be.
Old Sep 21, 2018 | 7:48 PM
im checking the coil sunday. Hopefully that works
Old Sep 21, 2018 | 7:49 PM
none other than my o2 sensors because i had to delete the cats
