99 Suburban C1500 AC Problems
Problem: Air (hot & cold) blowing out foot vents only.
Already Tried: Replaced existing controller with used controller. Replaced "mode" door actuator with new one from parts store.
Other issues: AC recirculate does not light up on either controller. If the "fresh air" door is broke, will it still light up?
Comments: no matter were I put the vent selector it blows at the foot only. Are there possibly some fuses that power these actuators? Maybe I have two bad controllers? Maybe parts house sold me a bad actuator?
HELP
Thanks, Eric
HELP
Thanks, Eric
Do not apply 12 volts to the actuator unless it is installed. It will go all the way to one side and get stuck and become unusable. I did this once and had to take it apart and realign the gears to get it working again.
I am testing it with a multimeter - taking the plug connector off and then testing the plug with the key in the on position. I get 12 volts at the mode door but not the blend door (which by the way looks hard as heck to get off - there is a steel bar in the way)
Going to pick up a new controller today since both tested the same.
sirreldar
Mar 31, 2013 11:02 AM
Night Train
Jul 16, 2011 1:29 PM
tangsoodn
Nov 26, 2010 11:39 PM
