99 Suburban C1500 AC Problems
Old Sep 14, 2012 | 10:47 AM
Shultzee13's Avatar
Default 99 Suburban C1500 AC Problems
Problem: Air (hot & cold) blowing out foot vents only.
Already Tried: Replaced existing controller with used controller. Replaced "mode" door actuator with new one from parts store.
Other issues: AC recirculate does not light up on either controller. If the "fresh air" door is broke, will it still light up?
Comments: no matter were I put the vent selector it blows at the foot only. Are there possibly some fuses that power these actuators? Maybe I have two bad controllers? Maybe parts house sold me a bad actuator?
HELP
Thanks, Eric
Old Sep 14, 2012 | 11:02 AM
There are 3 actuators in the truck. Maybe you changed the wrong one. Maybe the door is jammed and the actuator is still good.
Old Sep 14, 2012 | 11:09 AM
Shultzee13's Avatar
Thank you sir. How would I know if a door is jammed? Is there a way to test these actuators off the vehicle?
Old Sep 14, 2012 | 7:28 PM
Shultzee13's Avatar
Got 12 volts at the mode door, nothing at the blend door O. Tried both used controllers and nothing.
Sound like I need to replace the controller????
with a new one?
Thanks.
Old Sep 14, 2012 | 9:32 PM
MDTAHOE's Avatar
Professional Mechanic
Apply voltage to blend door if it moves problem is the controller
Old Sep 15, 2012 | 8:30 AM
Do not apply 12 volts to the actuator unless it is installed. It will go all the way to one side and get stuck and become unusable. I did this once and had to take it apart and realign the gears to get it working again.
Old Sep 15, 2012 | 9:06 AM
Shultzee13's Avatar
I am testing it with a multimeter - taking the plug connector off and then testing the plug with the key in the on position. I get 12 volts at the mode door but not the blend door (which by the way looks hard as heck to get off - there is a steel bar in the way)
Going to pick up a new controller today since both tested the same.
Mzchev
Jul 27, 2013 1:01 AM
sirreldar
Mar 31, 2013 11:02 AM
Night Train
Jul 16, 2011 1:29 PM
tangsoodn
Nov 26, 2010 11:39 PM
jmmass
Mar 8, 2009 4:27 PM
