'99 suburban heating problem
Old Oct 7, 2006 | 1:29 AM
falconhawker's Avatar
Default '99 suburban heating problem
I have a wierd problem. My Sub has the rear heat option. It blows warm/hot (in the rear) according to the temp setting. The front heat coming from under the dash stays cool. It will warm up on it's own, then cool back down. While traveling on the highway, if I accelerated, I would get heat almost immediately, blow warm for a few minutes, then cool off. It happened EVERY time I accelerated. My coolant is at proper levels. Is there a "door" in that aasembly between the blower & the vents that is, maybe .....stuck? Control panel problems? What? HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Thanx in advance.[][][][]
Old Oct 9, 2006 | 7:17 PM
uncle bill's Avatar
Default RE: '99 suburban heating problem
It could be a couple of things. You could have a restriction in the heater core, or a bad heater water valve or the engine may not be running hot enough to sustain a hot airflow through the heater.
Old Oct 10, 2006 | 1:55 PM
ZX1100F1's Avatar
The heater control valve is vacuum actuated (spring loaded closed/vacuum open), if there is a leak in the vacuum line(s) or a defective valve the flow of coolant will stop when the engine vacuum is reduced like during acceleration.
This is a very common problem and not too costly to have diagnosed and repaired.
Old Oct 19, 2006 | 10:06 PM
THANX EVERYONE FOR YOUR RESPONSES.....GONNA LOOK INTO THAT HEATER CONTROL VALVE.......I ASSUME IT'S THAT "UNIT" THATS SITTING ON THE HEATER HOSES PRIOR TO THEM ENTERING THE FIREWALL
Old Oct 19, 2006 | 10:35 PM
ZX1100F1's Avatar
Bingo!
Old Mar 24, 2010 | 10:25 PM
dadoffour's Avatar
So my heater valve was leaking too and the vacuum line was hanging loose from just the valve end. After replacing the valve I need to reattach the vacuum line... but I have no idea where it goes. Anyone know?
Thanks,
Do4
steffensp
Dec 11, 2008 8:25 PM
gromelc
Sep 29, 2008 9:37 PM
mattk72
Nov 27, 2007 10:03 AM
Biggestofsmall
May 15, 2007 7:10 PM
Ebmo
Jan 25, 2007 4:25 PM
