99 Suburban Rear Heater Lines
Old Sep 13, 2014 | 10:48 PM
Siberian's Avatar
Default 99 Suburban Rear Heater Lines
A while (9 months ago) back, I took my car into the shop for some work. This week my suburban started spewing antifreeze under passenger side door. When I looked underneath, I saw the shop had disconnected the rear heater and connected a short loop of hose onto the nipples coming from the front. This hose is what split and started leaking. I figured I would just blow out the lines going to the rear to make sure they were clear of obstructions and thyen plug them back up as they were intended to be. I put new plastic retainer clips on both connections, but when I filled the radiator, the connections started leaking like crazy. Is there a gasket or something I am missing?
Old Sep 14, 2014 | 10:45 AM
Welcome to the forum, a gasket or seal would be my guess, but why did the shop by-pass it and not fix it to began with?
Is it the quick connections that are leaking at the rear heater core?
Old Sep 14, 2014 | 12:12 PM
Siberian's Avatar
Thanks inPro2 - it is the connection. I can't recall what all they did in the shop that might make them disconnect the lines. Had it not been nine months, I would take it back to them. I can't find any reference to a gasket, but that is all that makes sense to me.
rbailey644
Oct 2, 2012 8:26 PM
usmarine0905
Nov 25, 2011 4:30 PM
jffgin
Sep 16, 2007 5:42 PM
jffgin
Sep 8, 2007 3:23 PM
MudHawg
K5 Blazer
Sep 28, 2006 3:45 PM
