99 Tahoe
Old Apr 29, 2023 | 12:35 PM
Yamni333's Avatar
Default 99 Tahoe
I have a 99 Tahoe that made a pop and then stalled out on the interstate so I’ve changed out the coil ignition control module timing chain and distributor cap and it started up ran for a few minutes and then died like it had no gas even though there was half a tank in it and the fuel gauge read empty so when I try the fuel pressure it goes up to 60 when you turn the key on but just drops back down to 0 after a couple seconds would this be the fuel pump?
Old Apr 29, 2023 | 2:09 PM
oilcanhenry's Avatar
Almost a certain possibility, to be sure.
Old May 1, 2023 | 11:02 AM
Welcome to the forum.
You should check the voltage to the fuel pump to see if it's getting voltage when it's not providing pressure.
Old May 1, 2023 | 12:20 PM
Moving to the Tahoe section of the forum where you will get more views.
Old May 5, 2023 | 7:08 PM
Might also be the fuel pressure regulator gone bad. And welcome to Chevrolet Forum, Yamni333.
