99 Tahoe no start
I have a 99 Tahoe 350 at 115.xxx. It has a hard time starting but when it dose start for the day it has no problems until you let it sit overnight. I've replaced the starter, coil, timing chain, crank sensor, coil pickup sensor, fuel filter. I hook a fuel gauge up it's a 60psi with key on then drops to around 55psi while cranking. Any ideas on what it could be
That is what is happening, but its not supposed to do that. That is why it has to crank so long, it has to build enough pressure to start, and that takes a while. If you install a check valve in the fuel line, just above the rear axle, it will mostly cure the problem.
Thermool
Jun 20, 2009 6:41 PM
wildboy74ss
Apr 1, 2009 5:10 PM
izod
Feb 14, 2009 2:42 PM
larry_chip
Jun 2, 2007 3:20 PM
