99 Tahoe OBS ABS and Security lights
Old Dec 28, 2021 | 11:52 AM
Friday24's Avatar
Default 99 Tahoe OBS ABS and Security lights
Just bought a 99 Tahoe 4X4 OBS and replaced all the dash lights, now when I turn the key to run all the lights illuminate as normal but then the ABS and Security lights don't go completely out, they just dim way down. Any ideas on why they would just dim and not go completely out? Thanks in advances.
Old Dec 28, 2021 | 3:40 PM
hanky's Avatar
What kind of bulbs did you install?
When you plugged the circuit board back in , could you maybe have pushed out or lost a connection at that plug?
Old Dec 28, 2021 | 4:20 PM
Friday24's Avatar
I used LED's on for all of the bulbs. I pulled the dash back out and swapped those 2 back to normal bulbs and they go out as normal. My guess is there is a small amount of current staying applied to those circuits which is enough to dimly light an LED but not enough to light a standard bulb.
Old Dec 29, 2021 | 8:48 AM
repairman54's Avatar
You got it. Sometimes LED do not play well when retrofitted into an incandescent circuit.
Justin Weber
Mar 27, 2017 10:58 AM
Mark Sladden
Nov 22, 2011 10:09 PM
mingito
Sep 10, 2009 3:32 PM
inatahoe
Aug 25, 2007 3:57 AM
26tahoe
Aug 19, 2006 3:43 PM
