99 Tahoe Won't Start...
I drove my 99 Tahoe on some errands. Got in my truck to drive and it wouldn't start. This happened the other day when I went to the store. I waited about 20 minutes and it started up. This time it won't start up again. It's turning over and sounds like it's trying.....any help or suggestion to get it started?
thanks a mill for the input!
RE: 99 Tahoe Won't Start...
nice. i don't have a book on this vehicle. i just recently purchased this ride. do you have a link for replacement of the filter / pump....or it's there whereabouts under the hood?
thanks again!
thanks again!
Fuel filter is located inside frame rail just beneath driver door.
The fuel pump is in the tank and if you require instructions to replace it is probably beyond your capability, it is not an easy job; the tank must be dropped.
close the hood. The fuel pump is inside the gas tank. The filter is inline, under the vehicle, inside the frame rail near the transmission crossmember on the driver's side.
ZChevyAK
November 13th, 2015 6:45 PM
larry_chip
June 2nd, 2007 3:20 PM
mgshilling
September 17th, 2006 1:28 AM
