ABS Light and Crunch sound
Old Dec 26, 2013 | 8:12 AM
  #11
I would not change the abs pump without first seeing what dtc has set in the ebcm. Its common for a bad wheel speed sensor signal to cause the pump to activate.
Old Dec 26, 2013 | 8:43 AM
  #12
UNDERSCORE's Avatar
Have you checked all your calipers to see if something is jammed there?
Old Dec 26, 2013 | 12:11 PM
  #13
waterdowg's Avatar
No I have not. I never even thought to do that since braking has been fine and I only hear the noise once I hit 5 mph. I drove around the block at low speed. Once I went over 5 mph, the cruch noise would happen the ABS light would come on. Then as I drove no other noises would sound.
I will get the computer and hook it up and see if I have acode anymore.
Old Dec 26, 2013 | 2:54 PM
  #14
does your computer read chassis codes?
Old Jan 2, 2014 | 7:02 AM
  #15
waterdowg's Avatar
Sorry for the delay. I have not been around a computer. Yes it did have a code, but I don't remember what it was. I will have to see if I have it written down somewere.
I have not had a chance to hook up the computer again as my brother now has it. Once I get it back I will post if there is a code still. But since the 24th the light has not comeback on nor has it made any noise.
Old Jan 2, 2014 | 8:35 AM
  #16
Sergio Lisboa Machado's Avatar
Hi Waterdowg, may be I am being silly, but another reason for the crunch sound is something wrong with the front differential, if it has worn bearings and stuck when on 4x4, before going to 4x2 it can make this sound and immediately the ABS light goes on and some time before it goes off. I suggest have the readings on a scanner before servicing anything.
Best regards,
Sergio
Old Jan 2, 2014 | 11:53 AM
  #17
waterdowg's Avatar
Best regards,
Sergio
Hmmm... intersting thought. The issue starte back in June/July so I was not using 4wd. The sound and light has every time I drove the car from that point up until the 24th. At no time dis the light every not come on during that time.
Does this still sound like it could be a bearing? I have used 4wd and it seems to work fine.
I'm going going to service anything yet. The code reference back to a ABS. I will have to look for it.
Old Jan 3, 2014 | 4:26 AM
  #18
Ok, I hope you can find the problem. On my burb, unfortunatelly this was the reason, I have changed the front differential oil and now I am using it on 4x2 until the new bearings arrive.
Old Jan 3, 2014 | 8:17 AM
  #19
waterdowg's Avatar
Do you have a cruch sound when you first start driving? If so does it go away? Mine seemed to happen right at the point the ABS pump would activatite. This the reason I suspected the pump.
Old Jan 3, 2014 | 10:32 PM
  #20
so the crunch noise was not the abs pump activating correct? It will make a buzzing noise.
