AC Button, True Function
Old Apr 19, 2010 | 8:35 AM
mikecallery's Avatar
Default AC Button, True Function
Some told me to crank up my ac, get the vehicle cool, and then turn off the ac via the ac button at the bottom of my control panel. Apparently the system will stay charged, and cool, and the ac compressor will not run, giving me better gas mileage. So, I tried it, and it works, but when I finished my trip, I popped the hood and saw the compressor on, though the switch was off.
With this in mind, what is the true function/nature of the switch? If the ac compressor is on, will it run 24/7 so to speak, and with it off does the compressor only go on periodically to charge the system? I'm confused.
Old Apr 19, 2010 | 12:19 PM
If the recirculate button is on the AC will be on
If the defrost is on the AC will be on
If the rear AC is on the AC will be on
Old Apr 19, 2010 | 4:29 PM
15 Year Member
Did you check the low pressure side to see if it was cold and wet?
Old Apr 19, 2010 | 8:41 PM
MDTAHOE's Avatar
Professional Mechanic
What year is the truck? What size is the engine? As in in2pro's post the compressor will be on if the **** is in any of those positions.
Old Apr 4, 2025 | 9:42 AM
kkkirimayne's Avatar
Understanding how different systems work can be tricky, especially when it comes to technical functions like AC compressors. On a different note, if anyone here is working on nursing assignments and needs well-structured examples, I found a great resource at nursing essay examples. They offer a wide range of nursing paper samples covering various topics, which can be really helpful for structuring your own work. Definitely worth checking out for academic support!
Jnino11
Jul 26, 2024 11:43 AM
Garon
Feb 7, 2024 7:07 PM
Rosselot
Jun 4, 2023 1:07 PM
bern10
Nov 15, 2006 9:07 PM
deveng
Sonic (Aveo)
May 14, 2006 10:56 AM
