Advice for Removing Rear Drums
tap the front and sides with a mini sledge using good firm raps it should loosen it off, after side and front taps, tap it off by the back lip fairly ligtly as not to wreck it
piquone: Welcome to the forum.
Also you need to back the shoes off a little cuz there is usually a lip on the edge of the drum. Might try some Kroil or other penetrant around the lugs. I have seen a drum puller that looks like a large gear puller.
SC300
July 19th, 2010 12:34 AM
