Airbag service message
Old May 31, 2017 | 5:52 PM
curtis1512's Avatar
Default Airbag service message
2008 suburban LT
I replaced the front drivers sensor back in 2015, worked fine. I replaced the passenger side today and I am still getting the service message. I used a Rock Auto sensor both times.
Would the message be coming from anything else?
Curt
Old May 31, 2017 | 8:45 PM
post the actual code that is setting.
Old May 31, 2017 | 9:17 PM
curtis1512's Avatar
Thanks, i'll get the code soon.
Old Jun 5, 2017 | 1:09 PM
curtis1512's Avatar
The Advance Auto guy checked it for me. it came up with no codes. I disconnected the battery for about 30 minutes, re-attached and the message is still there. I'm trying another Advance Auto today.
Old Jun 5, 2017 | 3:41 PM
curtis1512's Avatar
It appears the Advance Auto stores don't have the right scanner for airbags.
What else could the Service Aribag message be for.
Old Jun 5, 2017 | 9:05 PM
the only answer is; a fault in the airbag system. and yes code readers won't access srs codes. you need a full function scan tool. without the dtc there is no way to know where the fault lies.
