Any Transmission Gurus Out There???
Old Mar 14, 2007 | 7:02 PM
Dondobe's Avatar
Default Any Transmission Gurus Out There???
"1999" Automatic. While accelerating or climbing a grade it shifts perfectly. When you are on the highway and trying to hold a steady speed it go into a neutral state or slip. I have to let off the gas or speed up to make it engage again.
-No leaks
-Fluid is full
-Fluid is red & doesn't smell burnt
-Did scan and there were NO code !!
-While recreating the problem w/scanner on it, it showed it was still in lockup
-Serviced every 20K
Any suggestions would be appreciated!!!
Thanks, Dondobe
Old Mar 15, 2007 | 10:27 PM
dean828's Avatar
Default RE: Any Transmission Gurus Out There???
Serviced what every 20k?
Old Mar 15, 2007 | 11:54 PM
Dondobe's Avatar
I serviced the transmission (fluid & filter) every 20K
Dondobe
Old Mar 22, 2007 | 10:52 PM
kegbug's Avatar
if mechanically it appears in working order then it sounds like a sensor is either bad or going bad to tell the scanner its locked up but when driven its slips. either a factory manual or shop can show you the bazillion different issues to deal w/. i would start w/ the electrical part before dropping it for a rebuild kit or something else big money costing.
malibu613
Sep 30, 2013 6:27 PM
GeeGee-k10
K5 Blazer
Jan 9, 2013 10:45 AM
MNCDurst
Sep 23, 2009 10:49 PM
Mud_Truckin
Jun 4, 2009 1:53 PM
livinloud
Jan 10, 2007 5:13 PM
