anyone know which harness/pins power the sub?
Old Sep 7, 2008 | 3:02 PM
  #11
e's Avatar
e
Default RE: anyone know which harness/pins power the sub?
It appears thatthe nav unitsends a 4 channel high and low level's via plug 1/2. The bose amp sends the power to the factory sub. The bose probably gets its signal from the low level signals (F/R L/R)from the navand crosses it over at the amp and sends it to the sub. The question is are both the high and low level active at the same time? I do know that in the programming of the radio the dealer can make some type of changes in the audio outputs but i'm not sure which ones.
Old Sep 7, 2008 | 3:35 PM
  #12
VanDamme's Avatar
e can you also post what you have for the first three harnesses? your information is obviously more detailed that what i have. i'm begining to wonder if what i have is even correct...thanks
Old Sep 7, 2008 | 9:32 PM
  #13
shawnvw's Avatar
Banned
VanDamme....splice in a set for RCA cables into the wires for the low level LR speaker, and RR Speaker, and run them to your aftermarket amp. Providing it it has a built in crossover all should be good. Otherwise...its like e said....the amp takes the signals from the other speakers and puts out a sub output.
Old Sep 8, 2008 | 6:37 PM
  #14
e's Avatar
e
I'm with shawnvw on this. Splice in the rca's and call it a day. Here's the Pin outs/in courtesy of the onethey call"ZX1000F1"
Thats right i said it....
14-Pin Connector C1:
Pin Wire Color Circuit No. Function
1 RD/WH 340 Battery Positive Voltage
2 TN 201 Left Front Speaker Output (+) (UQ3)
TN 511 Left Front Low Level Audio Signal (+) (UQA/UQS)
3 L-GN 200 Right Front Speaker Output (+) (UQ3)
L-GN/WH 512 Right Front Low Level Audio Signal (+) (UQA/UQS)
4 PK 5149 Voice Recognition Audio Signal (UE1)
5 PK/BK 5152 Low Reference (UE1)
6 WH 7066 Entertainment Remote Enable Signal
7 YE 6817 LED Backlight Dimming Control
8 BK 2550 Ground
9 GY 118 Left Front Speaker Output (-) (UQ3)
D-GN 1947 Left Front Low Level Audio Signal (-) (UQA/UQS)
10 D-GN 117 Right Front Speaker Output (-) (UQ3)
OG/BK 1546 Front Low Level Audio Signal (-) (UQA/UQS)
11 Bare 2011 Drain Wire (UQA/UQS)
12 Not Used
13 D-GN 5060 Low Speed GMLAN Serial Data
14 Not Used
16-Pin Connector C2:
1 BN/WH 367 Remote Radio Left Audio Signal (U2K)
2 D-GN/WH 368 Remote Radio Right Audio Signal (U2K)
3 Bare 2099 Drain Wire (UQA/UQS/UK6)
4 L-GN 7396 DVD Video Signal 2 (+) (DNU)
5 BN 199 Left Rear Speaker Output (+) (UQ3)
BN/WH 599 Left Rear Low Level Audio Signal (+) (UQA/UQS)
6 D-BU 46 Right Rear Speaker Output (+) (UQ3)
D-BU 546 Right Rear Low Level Audio Signal (+) (UQA/UQS)
7 D-BU 658 Cellular Telephone Voice Signal (UE1)
8 OG 6978 Amplifier Control (UQA Except Y91)
9 TN/WH 372 Remote Radio Audio Output (-) (U2K)
10 GY 388 Remote Radio Right Audio Signal (U2K)
11 Bare 1573 Drain Wire (U2K)
12 WH 7394 DVD Video Signal 2 (-) (DNU)
13 YE 116 Left Rear Speaker Output (-) (UQ3)
BN 1999 Left Rear Low Level Audio Signal (-) (UQA/UQS)
14 L-BU 115 Right Rear Speaker Output (-) (UQ3)
TN 1946 Right Rear Low Level Audio Signal (-) (UQA/UQS)
15 L-BU/BK 659 Low Reference (UE1)
16 D-GN/WH 7395 Video Mode 2 Signal (DNU)
16-Pin Connector C3:
1 YE 2059 Auxiliary Audio Left Signal
2 WH 2058 Auxiliary Audio Right Signal
3 L-BU 5826 Left DVD Audio Signal (+)
4 WH 5828 Right DVD Audio Signal (+)
5 OG/BK 5831 Remote Infra Red Signal (+)
6 PK/BK 5844 Video Bright Control
7 D-GN 6975 DVD Video Signal (+)
8 PU 2056 Auxiliary Video High Signal
9 Bare 5345 Drain Wire
10 L-GN/BK 5845 Video Module Signal
11 PU 6979 DVD Audio Common
12 Bare 6980 DVD Audio Shield
13 TN/WH 5830 Remote Infra Red Signal (-)
14 Bare 6976 DVD Video Drain Wire
15 WH/BK 5335 DVD Video Signal (-)
16 Bare 5346 Video Drain Wire
16-Pin Connector C4:
1 Not Used
2 Not Used
3 D-BU 6760 Center Channel Low Level Audio Signal (UQS)
4 WH 6763 Subwoofer Low Level Audio Signal (UQS)
5 D-GN/WH 817 Vehicle Speed Signal (UVC)
6 PK 6972 Camera Signal #2 + (UVC)
7 L-BU 6973 Camera Signal #2 (UVC)
8 PU 5837 Amplifier Audio Prompt Signal (+) (UQS)
9 Not Used
10 Not Used
11 OG 6761 Center Channel Low Level Audio Signal (-) (UQS)
12 PK 6762 Subwoofer Low Level Audio (-) (UQS)
13 Bare 6759 Drain Wire (UQS)
14 Not Used
15 Bare 5838 Drain Wire (UQS)
16 GY 5836 Amplifier Audio Prompt Signal (-) (UQS)
Old Sep 8, 2008 | 10:41 PM
  #15
charlie pachanga's Avatar
AMP output sub one
Dark blue/ white (+) pin 1 (UQS/UQA + Y91)or pin 7 (UQA-Y91)
light green/ black (-) pin 2 (UQS/UQA+Y91)or pin 8 (UQA-Y91)
Second sub
Light blue/black (+) pins 3 (UQS/UQA+Y91) or pin 2 (UQA-Y91)
Dark Green (-) pins 7 (UQS/UQA + Y91) or pin 6 (UQA-Y91)
In harness, under cup holder compartment, inside center console.
Old Sep 9, 2008 | 8:25 PM
  #16
shawnvw's Avatar
Banned
those wires won't be there as the vehicle was not built with the amp\sub.
Old Sep 9, 2008 | 9:30 PM
  #17
That is why you should check you RPO codes in glove box. The info is for those that can use it.
guvner
Jan 1, 2012 3:14 PM
bgpunk2001
May 20, 2008 10:53 AM
jcw1500wt
Mar 24, 2008 11:07 PM
hardwarz
Oct 15, 2007 12:17 PM
