Anyone put their Tranny in tow/haul mode
Old Jan 2, 2007 | 11:32 PM
Clay24's Avatar
Default Anyone put their Tranny in tow/haul mode
I heard a rumor that if you put your tranny in tow/haul mode while cruising at 75 it will make the motor go into v4 mode resulting in better fuel economy
Old Jan 3, 2007 | 11:09 AM
marcoman's Avatar
Default RE: Anyone put their Tranny in tow/haul mode
try it and let me know!
Old Jan 3, 2007 | 6:54 PM
addkev's Avatar
On the highway it doesn't make a difference for me, I think it is probably the wind resistance. However, cruising around town it definitely makes a difference. The ride is a little harsher (shifting) but it does help it stay in V4 longer and not just when coasting. There is an art to it, you have to be light on the pedal but it works.
Old Jan 3, 2007 | 7:46 PM
konasmrz's Avatar
I'd be surprised if this actually helps because every vehicle I've ever owned with a tow/haul switch disables the overdrive & lockup in the torque converter. Resulting in higher rpm's / less economy/ more drivetrain wear. Also, I did notice a shift pattern change when in tow mode which appears optimized to keep the rpm's & torque curve up.
Old Jan 3, 2007 | 7:56 PM
addkev's Avatar
With the Tahoe and alot of newer vehicles the tranny will go into lock up and overdrive in tow mode, it just does it at a higher RPM. And using tow mode increases the line pressure resulting in a harsher, quicker shift which is actually better for a tranny. A longer smooth shift is actually harder on the transmission.
Old Jan 4, 2007 | 1:37 AM
I've tried it in town at 35-45 mph and it definitely improves mpg for me but you have to go back to normal when on level and downhill to get back in to OD and lockup. Saw no difference at hiway speeds as it stays in OD & lockup. Biggest change came when I went to Mobil 1. About plus 0.5 mpg calculated over several tanks.
mroakdale
12
Sep 28, 2024 6:06 PM
damone
Apr 29, 2011 7:36 PM
Red Ron
Oct 22, 2008 9:35 AM
steved
Nov 27, 2007 1:27 AM
racerx55
May 17, 2007 8:05 AM
