Arm rests - 2nd row buckets Suburban LTZ 07
Old May 13, 2011 | 8:33 AM
gamecock's Avatar
Default Arm rests - 2nd row buckets Suburban LTZ 07
should they be "loose" meaning they feel loose giggling left to right? Is this as simple as pulling off the cap and tightening the bolt? Anything I should be aware of - obviously making too tight would be an issue...
Old May 13, 2011 | 8:51 AM
ousig2408's Avatar
you probably just have some "play" in it from use. ours do not move back and forth so like you say you can probably look at it and lightly tighten it up. too much and it probably wont go up and down
Old May 13, 2011 | 3:50 PM
Does is appear to be moving wrt to the floor? If so, then tightening would be in order.
Old May 13, 2011 | 4:57 PM
ChevyFreak's Avatar
As the others have stated, taking off the cap and tightening the bolt should solve your problem. I do not think you have to worry about over tightening - worst case scenario the arm rest's just won't go up and down, and then you will just have to loosen them a little.
Just tighten each bolt under the cap and you should be good to go!
Old May 18, 2011 | 3:49 PM
Official GM Rep
I agree with the other users that you should try to tighten the bolts. If that does not work, please let me know.
Thank you!
Elizabeth, Chevrolet Customer Assistance
Old Nov 7, 2014 | 10:42 AM
UberKnight's Avatar
Default Replacing Arm rest Bolt
Hi , i know this thread is old but I need your help . I cranked the arm rest on my 09 Suburban Bucket seat and broke the bolt armrest right off from the base on the pass side . Does anyone know the part number for the seat attachment that comes with bolt to the seat assembly . Any help plz !
Old Apr 30, 2018 | 11:39 AM
LimoRick's Avatar
Question
Have you had any luck finding the bolt? Mine broke on my 07 Suburban and I have been having a hard time to find a replacement.
darthburban06
Apr 14, 2018 8:49 PM
phiestand
11
Sep 8, 2014 5:57 AM
LASD-SEB
Sep 9, 2013 12:33 PM
SuburbanOhio
Aug 13, 2009 8:34 PM
BTiddleybocker
Jun 21, 2008 8:37 AM
