autoride
Old Jun 9, 2012 | 11:42 AM
hunterjo's Avatar
Default autoride
i have a 2001 suburban 1500 4x4 with autoride. problem is service ride control message is on all the time. the system seems to working fine. it will level out when started , it will level out when i put weight in back. the pump seems to be working ok and it seems to turn on and off as the height at the back of suburban changes. i dont have the real high dollar scan to check that part of system. hope to from some with some pointers.
thanks hunterjo
Old Jun 9, 2012 | 8:23 PM
Get a free scan at most autoparts stores and that may shed some lite if there are any DTCs set.
Old Jun 9, 2012 | 9:03 PM
hunterjo's Avatar
the auto parts stores told me their scaner will not get any DTC,s that are set for that problem.
Old Jun 11, 2012 | 8:38 AM
hunterjo's Avatar
i have one more question it has to do with the positioning senors on each wheel. is there a way to check them without a scan tool. is there a ohm,s reading i can take or some other reading.
Old Jun 11, 2012 | 11:47 AM
Can't answer that one. While it probably is a potentiometer, I don't have a clue as to what a nominal value should be.
Unless someone else here has some ideas, probably have to take it to the dealer.
Old Jun 11, 2012 | 2:04 PM
SabrToothSqrl's Avatar
Default ohm meter
I would think that if you inspected each sensor (4) the odd one out would be the bad one.
Old Jun 11, 2012 | 6:05 PM
hunterjo's Avatar
that is my same thought. i will give that a try and i will let ya know the results. it might be a couple of days before i can get to it.
Old Jun 26, 2012 | 7:53 PM
hunterjo's Avatar
Default fixed problem
i solved the problem. first i took ohms readings on each sensor. i got between 400-600 ohm readings on all but one.( the different readings was because i was reading between the three different wires) the forth one had a open reading. i could not find a used one anywhere so i ordered a new one. installed it and problem gone. hope this info will help someone else.
hunterjo
Old Jun 27, 2012 | 4:50 PM
ArnottInc's Avatar
Former Sponsor
Default Convert your Autoride to Arnott Coil Springs
NEW Arnott / Bilstein Coil Spring Conversion Kit
<TABLE border=0 width=285><TBODY><TR><TD>Arnott is pleased to announce they have a new conversion kit to safely and effectively remove your factory installed electronic suspension on your Chevy Tahoe, Avalanche or Suburban. Our complete conversion kit features new specially tuned rear coil springs and four custom designed Bilstein shock absorbers made in the USA! This kit also includes new technology to reliably eliminate any fault codes on your dash panel. This connects directly to your vehicles electronics in the matter of minutes.
KIT INCLUDES:
New Rear Coil Springs
Front Bilstein Monotube Shocks
Rear Bilstein Monotube Shocks
Exclusive Suspension Fault Module
Detailed Installation Manual
</TD></TR></TBODY></TABLE>
Price is $685.50
Chevrolet Fourm members - Save 10% (up to $75) on Arnott Air Suspension Products by using code "GMForums0312" either as a SpecialPromotion code in the Arnott Web Store or by calling Arnott Customer Service at 800-251-8993.
Offer ends Saturday, June 30, 2012. One code per order.
Old Jun 28, 2012 | 2:53 PM
Sounds like a great system.
Is it available for the GMT900 models also?
Also does it void any warranties?
