Axle shaft bearing puller/driver
Old Feb 2, 2015 | 6:46 PM
Bryris's Avatar
Default Axle shaft bearing puller/driver
I think my right rear wheel bearing is bad. I'd like to attempt to replace it myself. I've gone over the procedure and feel good about it except for pulling the bearing from the housing and driving it back in. I don't have the tools for it, so was hoping to get some specs for what to look for. Knowing my luck, I ordered something from the net only to see it is wrong because I know nothing about them.
Anyone done this job at home? Are those bearings difficult to remove and replace?
2003 2wd suburban LT.
Thanks.
Old Feb 2, 2015 | 8:57 PM
this would remove the bearings
Error
this would install the bearing and seal
Error
hope the links work.
Old Feb 3, 2015 | 5:07 AM
Bryris's Avatar
The links don't work.
Old Feb 5, 2015 | 9:29 AM
I pm the links to you
Old Feb 6, 2015 | 11:46 AM
Bryris's Avatar
Thanks.
I got the links. Thank you!
97Silverado1500
Nov 3, 2012 8:58 PM
grschell
Jan 30, 2010 11:50 AM
lknox21
Sep 5, 2009 7:29 AM
rich_ncal
Nov 23, 2008 9:51 AM
