Axle Wrap?
Old Apr 23, 2007 | 6:49 PM
Bottomgun's Avatar
Default Axle Wrap?
Hey, all.....So the problem occures after I come to a quick stop or go a little quick over a speed bump. There is a clunk from the rear of the vehicle when I let off the brakes and the rear sinks back down. I looked under the rear end while rolling the tires with the vehicle in park and saw the drive shaft and housing move up and down. I am pretty sure that should not happen.
I am unable to find much in the way of information on the net and thought I would try here. 1996 Tahoe 2WD. If more info is needed, please let me know.
Duane
Old Apr 23, 2007 | 8:44 PM
RonH's Avatar
Default RE: Axle Wrap?
Might have someone check your U-joints. Also,take a look at your rear brakes, especially if they are drum brakes, to make sure everything is OK there.
Old Apr 23, 2007 | 10:47 PM
ZX1100F1's Avatar
Another thing to check is the leaf spring bushings, old wore out rubber bushings can deform or crack and decay, this can produce some slop.
Old Apr 24, 2007 | 7:35 PM
Bottomgun's Avatar
Thanks for the tips. I am going to put it on a lift this weekend and start poking around.
vstone48
Dec 27, 2018 12:37 PM
Chevrolet Forum News
Feb 12, 2015 5:08 PM
Dec 30, 2014 5:28 PM
Dec 27, 2014 1:38 PM
EvansBlue
Jun 16, 2009 11:08 AM
