B0083 Front impact sensor 1
Old Aug 6, 2016 | 9:07 AM
EHOIV's Avatar
Default B0083 Front impact sensor 1
My air bag light came on. Scan said B0083 front impact sensor 1 which from what read is driver side one. I checked fuses first and there were good so I replaced sensor Olin the front end. Light is still on. What could be wrong or do I need to take it to someone to reset the codes? Thanks in advance for the help.
Old Aug 6, 2016 | 10:29 AM
if you replaced the sensor, the fault is probably an open/corroded wire or corroded connector.
inspect the wiring from the impact sensor back to the wiring harness.
Old Aug 6, 2016 | 1:58 PM
EHOIV's Avatar
Is the wiring easy to replace or do I have to take a bunch of other stuff apart to get to the end? If I find a corroded wire, can I get a new set at a place like autozone? Sorry don't have much experience with cars but trying to save a little money by not taking easy stuff to the dealership to fix. Thanks for the help.
Old Aug 6, 2016 | 2:54 PM
Welcome to the forum.
Need to clear the code to determine if the sensor was the real problem.
