Ball Joints, what else to do
Old Oct 14, 2011 | 2:50 PM
BigDaddyO's Avatar
Default Ball Joints, what else to do
I'm going to be replacing both upper ball joints on my 99 burb 4x4 and I'm wondering if there is anything else I should do pro-actively since the front end will be torn apart? There is 190k miles on it.
Oh, I'm also going to replace the rotors and pads since the shop says they are at 30% and it flutters pretty bad when breaking. I'm pretty limited on my DIY auto stuff. I have replaced spark plugs, alternators, batteries, other small stuff. This Ball Joint is by FAR the biggest thing I will be doing so any pointers to make it easier would be greatly appreciated.
If that goes well, i'm going to be replacing the leaking valve cover gaskets.
Old Oct 14, 2011 | 6:40 PM
maxxman04's Avatar
i would replace the lower ball joints as well, since you'll be in there anyway. rent a ball joint remover/installer kit if your local parts store has one, makes life alot easier. also pay attention to the directions for installation. ball joints must go in turned a certain direction. check tie rod ends while you're in there.
Old Oct 18, 2011 | 11:09 AM
Idler arm should probably be replace also if it shows any looseness.
bigbare01
Jul 24, 2010 11:50 AM
HI808
Mar 12, 2010 3:24 PM
Mr.Cale
Feb 7, 2010 7:07 PM
quinnman105
Nov 24, 2008 1:53 AM
hometheaterman
Mar 30, 2008 2:07 PM
