Belt replacement
Old Mar 6, 2012 | 4:54 PM
WanderingOak's Avatar
Default Belt replacement
I've replaced the serpentine belt before on a 1988 S-10 with a 4.3 V6, but the belt on this 98 Tahoe with a 5.7 V8 has me stumped. On the 4.3, all I had to do was put a breaker bar on the tensioner, rotate it CCW, and the belt would loosen and come right off. On this truck, however, when I try to do that, all I wind up doing is loosening the bolt holding the tensioner on. The Haynes manual for this truck tells me to do exactly what I just did.
Is there a special procedure for changing the belt on this engine?
Old Mar 7, 2012 | 9:29 PM
cleveland63b's Avatar
pull the other way on the tensioner
Old Mar 7, 2012 | 10:03 PM
EinST's Avatar
There should be a square hole on the tensioner arm. Insert a 3/8" wrench or breaker bar into the hole and then turn it CCW.
Old Mar 8, 2012 | 1:31 PM
ah i had 5.3 on the mind...thats the 15mm you turn clockwise my bad
landon101
22
Nov 14, 2021 10:48 AM
OtherCarASaab
Aug 31, 2012 12:00 AM
Grem
Nov 12, 2007 12:22 PM
homer
Aug 26, 2007 7:12 PM
hollijb
Feb 12, 2007 12:21 PM
