Black Bowtie for front and back
Old September 1st, 2010 | 5:37 PM
WIESOX's Avatar
Default Black Bowtie for front and back
anyone have an idea where I can get the black bolt in Bowtie for a 2007 Tahoe LT?
Old September 1st, 2010 | 9:05 PM
I removed mine on the '07 and painted them both. Lot cheaper than aftermarket if you can even find one.
Old September 1st, 2010 | 9:29 PM
MDTAHOE's Avatar
Professional Mechanic
I did the same as 73shark but with white.
Old September 3rd, 2010 | 10:44 AM
WIESOX's Avatar
Thank you guys, I got the front one just about done. The rear looks much harder.
I used Black Mercury (Boat Motor) paint. 3 coats primer, 3 coats black, now comes the clear. I am going to do 2-3 coats clear. Looks great, so far.
Old September 5th, 2010 | 9:25 PM
If you mean the rear is hard to remove, just use fishing line or a credit card. There adhesive is a rubbery mat'l. Don't bend the bowtie very much as it will break.
Old March 15th, 2011 | 3:02 AM
Saltlife's Avatar
Default bowtie
I have a 08 silverado and i have glossy paint because, i wax it regulary. I want to paint my bowtie the same glossy paint as my color on my truck and Not flack black. What paint should i use?
Old March 15th, 2011 | 12:06 PM
Welcome to the forum.
I used Krylon Gloss Black on top of a adhesion promoter and then a clear coat. Duplicolor would work.
You'll need to color sand and buff to get rid of any orange peel.
Old March 18th, 2011 | 6:28 AM
08 burb fan's Avatar
Is there anything else but adhesive holding on the rear bowtie? I just want to take mine off my 08 Suburban.
Old March 18th, 2011 | 3:46 PM
Tyger's Avatar
All trim nowadays is held on with 3M automotive tape. Heat the bow tie with a hair dryer set on high. Don't overheat.. and remove it slowly. you can use a thin plastic putty knife to help lift. The excess glue can be removed with bug and tar remover.
Old March 18th, 2011 | 10:11 PM
Actually the rear bowtie is held on w/ an adhesive. Monofilament fishing line is the best way to get it off w/o risk of breaking it.
The front one is held on w/ two 10mm speed nuts and a small amount of adhesive.
