Blower motor help!!
Old Sep 4, 2015 | 8:00 PM
eglaze88's Avatar
Default Blower motor help!!
2005 suburban 1500 2wd base model:
Wiring to resistor fried a year ago, spliced and replaced, no issues. A week ago the connection from the resistor to the motor fried. Replaced the resistor and blower motor and it worked fine. I'm now smelling a faint odor of burning electrical and I can hear the squirrel cage making a clicking sound that is directly related to the speed at which the a/c is set. If it weren't for the slight burning smell I might think there was debris stuck in the blower. But if that were the case I shouldn't be smelling any burning, which leads me to the main question: Assuming the blower motor/resistor aren't defective, what would be causing these electrical issues? Is there too much juice going in and causing overheating? If so, what's the fix? Incidentally, we've been having a number of electrical issues (speedometer inoperable, oil pressure gauge registering way over the max line, occasional dash lights fade out/turn off entirely). Might this be due to a bad engine ground? If not, then what? Thanks for any advice. Hope we don't burn up in this thing...
Scotto2323
Aug 20, 2016 3:33 PM
spfx
Mar 17, 2012 6:15 AM
acasale
Jan 25, 2012 12:59 PM
nurse
Nov 3, 2011 5:04 PM
