blowing fuse when shift to 4x4
![Question](https://chevroletforum.com/forum/images/icons/icon5.gif)
![Confused](https://chevroletforum.com/forum/images/smilies/confused.gif)
Thanks
Location: Yuma Az. Born bred and raised to be an offroader
Sounds to me more like an actuator froze up. On the Independant fron suspension there is an actuator even though you have a floor shifter that puts the front axle into 4x4 if its bad it will blow fuses all day long check that the actuator isnt froze up you should be able to pull it off and connect 2 jumper wires from its pug directly to the battery and see if it moves back and forth if it doesnt thats your problem
fastblueheeler
August 12th, 2006 2:53 AM
