Bluetooth on 2009 Tahoe
#11
Yes the UPF code is on the glove box sticker. that tells me the system is "broke". Should a dealer be able to diagnose and define a fix? Maybe a reset of the system or firmware update? Something simple I'm hoping.
#14
I didn't see a blown fuse. Audio works through the system voice, through onstar. The system voice doesn't recognize commands. Previous owner says all factory audio.
Thanks for the suggestions
#16
#17
You may want to check with a local dealership's service department and see if they have a technician that is versed with the use of the Tech2 tool to re-flash that option if possible...
#18
That sounds like awesome advice. I have an appt this weds. Will check beforehand on the service tool. Thx all
#19
bluetooth not working
My Bluetooth on my 2009 Tahoe Hybrid just stopped working. I had to jump it off last week because of a dead battery. Does that have anything to do with it. How do I reset it so it will work. When I press the button for 2-3 seconds, it goes to On Sat.
#20
Diagnosis for my 2009 was VM module needed replacing. $612. Installed.
