Braided EGR Hose Help
Old Apr 10, 2010 | 1:09 AM
TPM's Avatar
TPM
Default Braided EGR Hose Help
Hello. Need a little help.
I am trying to get the coil off on a 96 K2500 GMC Suburban 7.4L. That alone is a chore.
There is an EGR hose on the driver side exhaust manifold that goes into the intake manifold near the EGR valve. That hose is blocking access to the left side bolt to get the bracket that holds the coil.
I can't tell how the hose is susposed to be disconnected. It looks like a typical hose fitting like the ones used for power steering. Only bigger - 1-7/8" wrench.
Anyone have experience with this hose- it is covered with a braided steel.
Old Apr 10, 2010 | 12:03 PM
TPM's Avatar
TPM
Default Update
Its a rubber hose with a steel braided shield over it. Does anyone know if the threads are left hand on the connectors?
Old Apr 10, 2010 | 1:00 PM
TPM's Avatar
TPM
Default Got it
Used penetrating oil and large wrenches, a friend and a pipe as a helper. Came off as expected. Made a big difference being able to reach the left side bolt to get the coil bracket off.
Newto4x4
Jun 19, 2013 11:51 AM
JLanzino
Nov 23, 2011 2:25 PM
Z71Grl08
Aug 2, 2011 8:12 PM
cblu007
Apr 12, 2007 1:20 AM
Fiesty96
Jan 25, 2007 4:49 AM
