Brake pedal side to side shake- how to fix
Hello all, 03 Tahoe, I am working on the highway vibration that some many seem to have. I think I am getting a handle on it. Might be the tires??? But in the mean time I would like to fix the side to side violent shake of the brake pedal when to car vibrates. When I reach down and move it bake and forth, well it moves back and forth. Seems very sloppy. Anyone else have this problem? Is there a bushing to fix it?
Thanks Kelly
Thanks Kelly
Not when braking. When driving down the road with out touching the brake pedal when the car vibrates - the brake pedal shakes back and forth (knock, knock, knock, knock) fast and load, As if the brake pedal shaft is warn or brake pedal bushings are warn. I can put my foot next to the pedal to stop it from knock side to side when driving. I was wondering if anyone knows of a fix for this. I can not seem to find and brake pedal replacements or shaft or bushings any were.
Thanks Kelly
Thanks Kelly
After a good look I ended up tightened the pivot bolt less then 1/4 turn. I looks as if there may have been some type of plastic shim or washer that has worn off. A small piece feel out when looking at it. Any way that fixed it. No more loud shake bake and forth. I guess a small spring washer would have worked too. I also solved the highway shake at 65 and above. One of the tires is bad or something. Put it on the rear and the shake has gone. I am guessing the rear suspension is stronger to stop the wheel hop.
Thanks Kelly
Thanks Kelly
