Broken Exterior Door Handles
Old Sep 19, 2015 | 11:18 AM
  #151
latif99's Avatar
Angry
It only took them 7 years to fix the problem until 2015 models.
Old Oct 23, 2015 | 10:00 AM
  #152
Mblanford's Avatar
Default 2011 Tahoe LTZ Door handles and door locks
My 2011 Tahoe LTZ that I bought new hasn't held up like my last Yukon did. Frankly I take very good care of my cars and this morning my passenger door handle came off in my sons hand when he went to open it. My drivers side door handle is jiggling so I guess I can expect the same for that one. In addition my door locks on the driver side are both not working and my front passenger seat motor works however it is stuck in a forward position and won't recline! What is going on? I take very good care of my cars and now don't have a seat, a handle or two locks! This is clearly the most expensive car I have bought new at over 50k, even with buying my last 07 Yukon new prior to this one. Chevy and GM have lost me as a future client.
Old Nov 24, 2015 | 6:27 PM
  #153
robeco's Avatar
I have a 2010 Sub LTZ. A 65k truck new and I cannot understand why GM refuses to address this issue. I have 2 broken door handle and a inside handle that cuts fingers like a razor. Took it to the dealership where they want to charge over 350.00 to fix when GM should be doing it free of charge since they know this has been a long standing problem. Or does someone need to die for GM to do the right thing?
Old Dec 8, 2015 | 7:39 AM
  #154
11Silverado's Avatar
I just bought a 2011 Silverado (yes I realize this is a suburban/tahoe thread) I have only had it since last Friday and the drivers door handle just popped loose this morning. It has 59,000 miles and only has the powertrain warranty remaining I believe. Any advice besides handing over hundreds of dollars to a dealership?
I also bought it from a non GM dealer so I doubt they will be much help.
Old Dec 8, 2015 | 8:27 AM
  #155
suburbansr4me's Avatar
It's a relatively easy and inexpensive DIY repair. 1AAuto has a video specifically for your truck.
When ordering the part, make sure you match up the year and passenger vs driver side, as well as front or rear.
All in, it cost me under 30 bucks. That includes the part and a plastic trim tool set from Harbor Freight.
Good luck
Old Feb 22, 2016 | 10:15 AM
  #156
Abel Carrillo's Avatar
Default Broken exterior door handles
Originally Posted by in2pro
Welcome to the forum...
the outside handles are not near as common as some other issues... did the handle just pull out or is it broken? it could be an issue of the cold weather causing things to shrink up....
I think someone had just posted a similar issue in the forum a month or so back so a search might give some more info... but as the day goes on others with start to chime in....
The same thing just happened to me today. The doorhandles are still operational, however, the whole assembly started to separate from the door. It will be just a matter of time before the whole handle assembly comes completely off after continued use. For an over $60,000 truck which I bought brand-new in 2011, this is the last thing I would expect. I think there is a problem here especially if I am not the only one experiencing it. I doubt that The manufacturer would even fix it because it sounds so minor compared to other problems and the warranty is already out of date. It is just sad that you pay so much money expecting quality and you get something like this.
Old Apr 14, 2016 | 3:02 PM
  #157
daveopal's Avatar
Old May 19, 2016 | 10:17 AM
  #158
Stacozo's Avatar
Default DIY fixes
Another great site to check for reasonably priced replacement parts for DIY fixes is Cheapest GM Parts - Shop the Cheapest OEM GM Parts. They have great prices and a ton of stock.
Old Jul 6, 2016 | 7:13 AM
  #159
gruvenparts.com's Avatar
Former Sponsor
Hi all,
Hopefully most have heard of Gruvenparts.com
We have solved the door lock actuators issue on these great trucks, as well as the folding mirror gear issue too.
Im looking for a new GM project - can this 1 be it ? If you want to help us, we'll provide FREE test samples of the improved design for your evaluation. Its obvious GM isnt going to fix this, and replacement handles also made the same way will just keep breaking over and over again. Perhaps its time we look at this issue closely and figure out how to design a fix.
If you want to help, please email me - paul@gruvenparts.com
I will need detailed pics and sample parts to evaluate how we can redesign this door handle from a better material.
Thanks and Im looking forward to working this project. Also, if you have other ideas for GM products we can look at, please let me know ! We are trying to add many more GM products to make these otherwise great trucks more durable !
Old Jul 19, 2016 | 9:56 AM
  #160
Former Sponsor
any takers on this idea ?
