Broken Exterior Door Handles
I see everyone posting that they are having the same problem, outer door handle breaking. My front passenger and rear driver side outer handles are broke. I'm looking to replace mine on my 2008 Suburban so I came here looking for answers. I know how to get the door panel off, but I was looking for some inside info on how to remove the old handle before I pull the door panel off. Anyone have pictures or hints as to how to do this after I remove my door panel?
attached PDF...
2007 Chevrolet Chevy Suburban - 2WD | Avalanche, Escalade, Suburban, Tahoe, Yukon (VIN C/K) Service Manual |
Document ID: 1741074
Front Side Door Outside Handle Replacement
Callout Component Name
Preliminary Procedures
1. Position the door window as needed for service.
2. Remove the front door trim panel. Refer to Front Side Door Trim Panel Replacement.
3. Remove the water deflector. Refer to Front Side Door Water Deflector Replacement.
Front Side Door Lock Rod Retaining Clip
Tip
1. Remove the rubber grommet to access the bolts.
2. Plug in the window switch and raise the window.
3. Release the handle lock rod from the door lock.
4. Release the door handle lock cylinder rod.
2 Front Side Door Outside Handle Lock Rod
Front Side Door Outside Handle Bolt (Qty: 2)
Notice: Refer to Fastener Notice in the Preface section.
Tighten
6 N·m (53 lb in)
Tip
Transfer the handle lock rod to the new handle.
Tip
Tighten
6 N·m (53 lb in)
Tip
attached PDF...
Tip
Tighten
6 N·m (53 lb in)
Tip
Tip
Tighten
6 N·m (53 lb in)
Tip
How exactly is the window suppose to be positioned for "service"?
And the Front Side Door Trim Panel and Water Deflector Replacements.....? Are there PDF's for those? Can you post those or send me in the right direction?
I will check for the other documents but "Position the door window as needed for service". means put the window in a position that best works for your needs so you can reach the retaining hardware. Maybe its all the way up, maybe all the way down maybe half or three quarters way.
Do not move the window while you have any tools or bodily appendage with in the door cavity.
I can't post the PDF's as they are too large, but here is the text of the documents....
Document ID: 1741457
1. Remove the door upper trim panel. Refer to Upper Extension Trim Panel Replacement .
2. Remove the door window control switch. Refer to Door Lock and Side Window Switch
Replacement - Driver Side and Door Lock and Side Window Switch Replacement -
Passenger Side .
Front Side Door Locking Rod **** Assembly
Procedure
1. Lower the window.
2. Ensure the locking rod is in the unlocked position.
3. Use a flat-bladed tool to disengage the detent tab and then remove the ****
by pulling upward.
4. When re-installing, push the **** down until the detent tab touches the
locking rod opening cover.
5. Push the detent tab in to lock the **** to the locking rod.
2 Front Side Door Trim Panel Cover
3 Front Side Door Trim Panel Cover Retainer (Qty: 3)
© 2012 General Motors Corporation. All rights reserved.
4 Front Side Door Inside Handle Bezel Cover
Front Side Door Trim Panel Bolt (Qty: 3)
Tighten
9 N·m (18 lb in)
Front Side Door Trim Panel Assembly
Procedure
1. Disconnect the electrical connectors.
2. There are 2 hooks located on the lower portion of the door trim panel that
are being used for manufacturing installation ONLY.
3. If these hooks are damaged during either removal or installation of the door
trim panel, replacement of the panel is not required.
4. When installing the trim panel start at the lock ****, pushing down and
outward moving toward the upper front.
Front Side Door Cable Retainer
Procedure
1. Depress both tabs to remove cable and pull cable rearward out of handle
assembly.
2. When reinstalling cable make sure that it is fully seated past the guide tab.
8 Front Side Door Trim Panel Retainer (Qty: 12)
Document ID: 1741457 Page 2 of 2
Passenger Side .
Procedure
by pulling upward.
Tighten
9 N·m (18 lb in)
Procedure
Procedure
assembly.
Document ID: 1741469
Remove the door trim panel. Refer to Front Side Door Trim Panel Replacement .
Tip
1. Use a flat-bladed tool to separate the bond between the sealer and the door.
2. Use waterproof tape, or 3M 777 or equivalent, if the water deflector is
damaged.
3. It will be necessary to replace trim panel retaining clips, if broken.
4. Before replacing the water deflector clean the door adhesive area, using a
50/50 mix of isopropyl alcohol or equivalent.
Document ID: 1741469 Page 1 of 1
Tip
damaged.
How To Install Replace Door Panel Silverado Sierra Avalanche Yukon Tahoe Suburban 07-12 1AAuto.com
How To Install Replace Door Panel Silverado Sierra Avalanche Yukon Tahoe Suburban 07-11 1AAuto.com - YouTube
I recently purchased a used 2007 Suburban LTZ. This weekend, both passenger side exterior door handles pulled away from the body. Is this common? I took it to the dealer, and they want $165.00 a piece to replace them. The car is out of factory warranty, but it seems to me that they would replace these at no cost on a vehicle that cost $60K new.
I saw that today when I was doing some searching but it still leaves me with a couple questions....
in2pro - Thanks for the 2 posts. I think that should help when I go to tackle the replacement of two handles this weekend. I was just a little afraid to take the door panel off and not know where to go from there. But I think with a little tinkering and the instructions you posted I should be able to figure it out. Thanks!
