Broken Pitman Arm
Old Feb 25, 2020 | 10:14 PM
Mtmn2020's Avatar
Default Broken Pitman Arm
Hello,
The pitman arm broke on my 2005 Chevy Suburban 1500 4wd. I spoke to a mechanic and he asked if the Suburban had a lift on it and I said yes. As it turns out it puts a lot of strain on it. Anyway, I pulled the gearbox and removed the pitman arm. When I installed the new arm onto the gearbox I accidently wrenched on the nut way too tight. I'm afraid I may have come close to stripping the threads or stretched out the bolt. I'm a little paranoid now that I've experienced losing steering. I was wondering if I should pull the nut back off and expect the threads and bolt and torque it to proper specifications or buy a new gearbox for $250 and try again?
Old Feb 26, 2020 | 12:01 AM
oilcanhenry's Avatar
Originally Posted by Mtmn2020
Hello,
I can't really give you any advice since this is a safety issue, but perhaps your instincts are telling you something that might save someone's life, including yours.
Old Feb 26, 2020 | 12:52 PM
Irish_alley's Avatar
I'm here for the party
what you could do is put a torque wrench on it and set it to manufactures specs for that nut and see if you get a click without the nut turning. if you do get a click turn it up a little and see when you dont get a click
ilike bikes
1988 - 1998 (GMT400)
Feb 10, 2020 8:50 AM
drodg99
Sep 7, 2019 8:02 AM
woodie1987
Nova & Chevy II
Dec 22, 2015 10:55 AM
Mudd Mutt
Aug 4, 2012 1:04 PM
maxxman04
Mar 9, 2010 5:34 PM
