Old August 6th, 2015, 2:19 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Interior Guides
Print Wikipost
Which BYPASS(s)? Viper or Autopage Alarm install
Old September 22nd, 2008, 10:04 PM
  #21
dsteinmann's Avatar
Default RE: Which BYPASS(s)? Viper or Autopage Alarm install
Old September 23rd, 2008, 10:50 AM
  #22
e
e's Avatar
Two things.
1. Ground the 1701g to a chassis ground, not metal bracing for the dash. Find a spot of Painted sheetmetal and scrape away to bare metal and ground at this point. I think this is the problem
2. Reset the 1701g via the instructions if the ground doesn't work.
Also are you getting the ignition feed for the viper from the 1701g?
take note to also turn off the feature on the 1701 for unlocking with key removal. On some platforms and different alarms we've seen this feature unlock the doors when the RS feature timesout...food for thought
Old September 23rd, 2008, 11:12 AM
  #23
dsteinmann's Avatar
By igintion feed do you mean the 12v constant Red wires on both the 1701g and Viper if so they are both tied into the red/white on the back of the drivers side Fuse center. Or if you mean the Igniton wire for the remote start the pink wire This is hooked up to the Pink wire off the Key.
Also the 1701 doesnt say anything about reseting except for the settings which would just be the ZAP feature. I will try that and turn off unlocking with key removal.
And the Ground iwill relocate when i get home Is it getting some type of EMI / Interferance or something?
Old September 23rd, 2008, 12:19 PM
  #24
e
e's Avatar
ORIGINAL: dsteinmann
Quite possibily........
The 12v feeds for the rear of the fuse panel are Red/Black.
Old September 23rd, 2008, 12:41 PM
  #25
dsteinmann's Avatar
Should i move both grounds over to the new point are just the 1701?
And the red/white must be fused going out to something. Is it nesccary to move this over to the Red/Black?
Old September 23rd, 2008, 12:58 PM
  #26
e
e's Avatar
I would use the red/black but thats me. I would and always ground my modules seperately.
Also when you cut the passlock 3wire, one side should of went to the 1701g orange/white and the other should go to anACCESSORY (orange)off the remote start. Did you do this?
Old September 23rd, 2008, 1:19 PM
  #27
dsteinmann's Avatar
ORIGINAL: e
Yes The Passlock3 was Brown Pin2. And i didnt need the 566u (its aAvalanche)
And i belive the key side of the Passlock went to the Orange/White of the 1701g
Old September 23rd, 2008, 3:13 PM
  #28
e
e's Avatar
[/quote]
[/quote]
correct.....and the other cut endgoes to the accessory from the remote start harness usually orange. Did you energize the cut end with the RS harness?
Old September 23rd, 2008, 7:21 PM
  #29
dsteinmann's Avatar
Ok i moved the ground 2 differnet spots same results turned off all the auto lock featuers on the 1701 NO change. But one time it unlocked right before it remote started then locked, and was good (isnt that what it should do)? I think im going to try another 1701g....... What do you think is that how its supposed to act by unlocking then relocking once started?
Old September 23rd, 2008, 7:54 PM
  #30
e
e's Avatar
pm'd
atex33
February 10th, 2013 12:18 AM
jcjoines
37
December 29th, 2011 4:44 PM
blackwidow1500
March 26th, 2011 10:30 PM
pjkem2
May 31st, 2010 8:48 PM
Quick Reply: Which BYPASS(s)? Viper or Autopage Alarm install
