Last edit by: IB Advertising
Browse all: Interior
- Chevrolet Silverado 1999-2006 GMT800 Why Doesn't Blower Motor Work
Step by step instructions for do-it-yourself repairs.
A/C not blowing in front, only when moving. Rear, ok.
well i went out and bought a blower but thats not the issue either. any other suggestions. i went to the dealer and spent 75 dollars thinking they would determine what was wrong and they said the blower but not the problem. can anyone help.
Have you checked the obvious things like fuses, and relays?
The blower speed select board can go bad, but usually it goes out one speed at a time. Sitll it's a possibility. I don't know where it is on the Tahoe, but it's typically mounted near the blower motor. On my wife's Jeep, it's mounted to the blower housing. It's a small board with a number of zigzag wires mounted to it; one for each speed. They're the only other things I could think of.
I have a 2003 chevy Tahoe and mine had to do with a bad switch thing under the passenger dash it worked in back but not front.one only cost about $60 to fix but I did it my self its called the blower resister module or something like that but you have to know if yours is the 2 prong or the 4 prong
what exactly was your Tahoe doing before you fixed it? mines doing the same thing like the original post states, I don't want to buy a blower if its the resistor, so maybe I might have the same issue you had so I could maybe change out the resistor, thank u
I have a 09 Suburban LTZ. The back blows out hot/cold perfectly. I can change the power of blow and everything. But the front doesn’t blow at all, unless moving then it flows decently well. I have replaced the resistor and checked the motor and it is perfectly fine. When I plug the motor into the resistor sometimes I get lucky and it’ll work. But it only works for maybe a day, if I’m lucky. Sometimes it’ll quit working within the hour. I have no clue what else to do.
