Old Jul 22, 2015, 12:38 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Interior
Print Wikipost
A/C not blowing in front, only when moving. Rear, ok.
Old Sep 16, 2023 | 4:32 PM
  #31
jakew's Avatar
first step in electrical problems is to check fuses
Please elaborate. You mean you feel air coming through the vents while the vehicle is moving?
I checked all fuses and troubleshooted them, fuses are all fine, and yes only when moving does it deliver any air.
Old Sep 16, 2023 | 5:42 PM
  #32
@jakew
On your vehicle the climate control system is controlled by two computers: the HVAC control module, and the blower motor control module.
It's going to require some comlex troubleshooting using a bidirectional diagnostic tool to narrow down the problem.
Old Dec 8, 2025 | 9:51 PM
  #33
tintsince97's Avatar
Originally Posted by John Kevin Williams (TheJohhnyCat)
I have a 09 Suburban LTZ. The back blows out hot/cold perfectly. I can change the power of blow and everything. But the front doesn’t blow at all, unless moving then it flows decently well. I have replaced the resistor and checked the motor and it is perfectly fine. When I plug the motor into the resistor sometimes I get lucky and it’ll work. But it only works for maybe a day, if I’m lucky. Sometimes it’ll quit working within the hour. I have no clue what else to do.
I have an 09 Suburban LTZ and im having the same problem. Nothing works up front the A/C or defroster, but the rear unit work just fine. did you have any luck?
Cableguy216
2007 - 2013 (GMT900)
Aug 2, 2019 2:07 PM
terrymanis1
Aug 29, 2014 9:03 AM
ssippi73
Jun 2, 2014 9:06 AM
Ditch Bitch
Sep 15, 2008 10:06 PM
jwboudreau
Jun 27, 2008 8:06 AM
