A/C Problems
The ac has stopped working in our Tahoe. The dash controls work and act like they should. Have checked it out and it is not getting power to fuse # 17,for the ac clutch. I have jumped it with 12 volts to the right side of the fuse and it will work fine, does want to freeze up when thaws out it will go back to working right, just don't like to jump it like that, afraid might do more damage. I think it is not getting a ground to the relay. I put in a new fuses box in it after ruining the original one by too much force on the fuses checking it out. Now that winter is just around the corner may not need it as much but need to get it to cycle with the defroster. Thanks Dan
The ac has stopped working in our Tahoe.... Have checked it out and it is not getting power to fuse # 17,for the ac clutch. I have jumped it with 12 volts to the right side of the fuse and it will work fine, does want to freeze up when thaws out it will go back to working right, .... I think it is not getting a ground to the relay. ....
