a/c shows it's overcharged
sup ppl just was wondering if anyone had any problems with their a/c overcharging. my 03' tahoe was working fine then all of a sudden i noticed check engine light came on and the engine began to run rough at idle. i could hear the a/c compressor turning on and off like it needed more refrigerant, so i checked it with an a/c gage and it showed that it was overcharged and i didn't even add any refrigerant to it. so can anyone please help me with any info you got it would be greatly appreciated.
aloha BAD
aloha BAD
the gauges are universal and the psi all depends on the ambiant temperature. i know ,for exaple, here in florida with a temp of 95-100, the system should hold a charge of 50-55psi. you can find a chart anywhere on the web. but dont just go by the cheapo gauge being in the yellow or red. those are just generic.
depending on what type of gauge or gauges you are using this link has a chart that can give some guidance...http://factoidz.com/auto-air-conditi...-hot-and-cold/
Here is another link I believe someone has posted in this forum before that has lots-o-good info... http://www.autoacforum.com/
aloha BAD
