Changed Rear Main Seal, cant go forward or reverse
I hope I have some luck on here.
So I had an oil leak On my 2001 Chevy Tahoe 5.3l V8 LS. I did the dye test and determined it was the rear main seal
So the next day I dropped drive shaft ,Trans, and exhaust. Replaced the rear main seal. I buttoned everything back up. The only thing I think I messed up is I took off the Torque converter completely to change the front seal on transmission. The TC lost alnost all fluid. The 2 sensor on shift actuator were extremely hard to push back in. In this process. So I button back up, fill with trans fluid, and turn it over. It makes a wierd noise for about 30 seconds and then runs normally. I get in and put in reverse . .... nothing. drive ...... nothing.... meaning I wasnt able to move. The shift actuator is moving when Im shifting. It stays in park while in park and I can push it while I am in neutral. The car would not move in 1,2,3 either. I am reading that I have enough fluid on dip stick. Any input on where to start with troubke shooting?
Last edited by Dominic Ferro; December 12th, 2016 at 2:55 PM. Reason: Gramner errors
I am not sure what you mean. I put about 8 quarts of trans fluid in through the dip stick. Then I started the truck and let it run . Dip stick is reading full. I think pump might of burned out when I started with no fluid in the torque converter
